Perfect. Now as you're able to boot, the next step is to patch the framebuffer.
As per the specs indicated in your profile, your Motherboard has 1xDP and 1xHDMI. So, patch these connectors only. You'll have to determine what physical connector corresponds to conX in macOS.
Also, ensure that you have 64MB DVMT set in BIOS.
Lastly, don't forget to remove "-igfxvesa" boot arg. Use DP and you should be able to login.
Iam a noob at framebuffer patching can you please do an understandable explanation about patching framebuffer?
Add the device property for the IGPU and add the ig-platform-id. Then, you need to set the connectors for DP and HDMI. Read the guide and you'll be able to get the key points.
Done making the patch (Still no acceleration)
That's not how IOReg is supposed to attach.
The Framebuffer patching isn't proper. Important parameters are missing.
Remove -igfxvesa from your boot args. You were asked to remove it previously as well.
Well how do i attach the IOReg?
biff
