Perfect. Now as you're able to boot, the next step is to patch the framebuffer.
As per the specs indicated in your profile, your Motherboard has 1xDP and 1xHDMI. So, patch these connectors only. You'll have to determine what physical connector corresponds to conX in macOS.
Also, ensure that you have 64MB DVMT set in BIOS.
Lastly, don't forget to remove "-igfxvesa" boot arg. Use DP and you should be able to login.
How to Enable Intel HD and UHD Graphics on macOS - Intel Framebuffer Patching Guide
An EliteMacx86 Exclusive Guide - This guide covers fixing Intel HD and UHD Graphics on macOS. By following this guide, you'll be able to enable Intel Graphics with acceleration on macOS with full QE/CI on your system. This guide also covers Intel Framebuffer patching and other important Graphics and Display aspects.
I. Overview
macOS supports a wide range of Intel HD Graphics (also referred to as iGPU) but some of them might not work out of the box if you have not followed...
I. Overview
- EliteMacx86
- black screen bus id patching clover connector patching desktop dvmt edid frambuffer framebuffer patching graphics ig-platform-id igpu intel intel hd graphics intel uhd graphics laptop macos opencore qe/ci whatevergreen
- Forum: Graphics and Displays
