MacPro 5.1 Sequoia Upgraded Airport (Native) Used Open Core BT OK but WIFI not turning ON, It worked on Big sur
lepartisan
Apple Mac Pro 5.1
Xeon
RX580
15.x
  1. OpenCore (Legacy)
  1. Mac Pro
That's normal. You'll need to patch the WiFi.
I actually know it must be patched, but how? what kext is the one? Sequoia not even detects WIFI only BT
Build the EFI using OCLP for your target hardware. Boot via that and then run Post Install Root Patch from OCLP and it will take care of rest!
I actually did that, no success!
That's weird. Provide the PR files to check further.
Guess What? opened the Mac, the Card was not well conected, thats why I had BT but no wifi Thanks
Initially, i thought the same but then i ignored thinking that may not be the case. xD
Glad its resolved. Marking SOLVED and closing this thread.
jillakd
