SOLVED RT.GV Failure for Sequoia AMD installation
Dsmitti01
ASRock A520M-HDV Micro ATX AM4 Motherboard
AMD Ryzen 9 3900X
RX 580
15.x
  1. iMac Pro
  2. Mac Pro
Hello, I am quite new to this and I'm getting a error message upon opencore boot screen.
Here are my specs...
AMD Ryzen 9 3900X CPU
ASRock AM4 A520M-HDV Micro ATX Motherboard
Sapphire Nitro+ RX 580 GPU
Kingston Fury Beast RGB 64GB DDR4-3600 RAM
Western Digital WD_Black SN850X 2TB SSD
Fenvi FV-T919 Adapter
I can upload any files necessary from the EFI drive if need be. Any help would be appreciated thanks!
To update, here is the current config.plist I have.
Your EFI isn't as per the guide
Here are a few issues. Make the following changes to your config.plist:
- Disable ResetLogoStatus
- Disable EnableWriteUnprotector and Enable RebuildAppleMemoryMap
- Enable SyncRuntimePermissions
- Disable FixupAppleEfiImages
- Remove NootedRed. 3900X does not have APU.
- Remove CryptexFixup. You shouldn't need this.
- If 4G Decoding is not available within the BIOS, then only use npci=0x3000.
I actually should have updated this a while ago. But after some trial and error doing I believe some of those steps, I actually got it to work. Everything works like a charm, Wi-Fi, Bluetooth and everything!
Sounds good. Marking SOLVED and closing this thread now.
ryusuke17
