CSM= Disabled
Secure Boot= Disabled
OS type= Other OS
Fast Boot= Disabled
DVMT Pre-Allocated= 64MB
IGPU Multi Monitor= Enabled
VT-d= Enabled
SATA Mode Selection= AHCI
Intel (VMX) Virtualization Technology= Enabled
Attach the revised EFI. Also, provide the BIOS settings.
I do get the Prohibited Symbol with a message saying "OCB: StartImage failed - Aborted"
CSM= Disabled
OS type= Other OS
Fast Boot= Disabled
VT-d= Enabled
The BIOS setting looks good. However, it seems like either you did not make the changes to the config.plist or have attached the wrong one.
Please make the adjustment as per the post #8.
The "post #8" hyperlink redirects me to the same thread which I created
You should see the following in the post #8. Double checked and the hyperlink is working as expected!
Yeah.. Still the same Prohibited symbol
Just to mention it third time that "You must make those changes in your config.plist, as outlined in the post #8". The main reason why you see prohibited symbol is because you are using iMac14,2 as SMBIOS which is unsupported.
The Prohibited symbol is gone but I am stuck at booting the OS
alvarg82
