Installer keeps freezing during the installation
fajardo
Asus X530FN
Intel Core i7-8565U @ 1.6GHz (Whiskey Lake-U)
Intel UHD620/NVIDIA GeForce MX150 2GB
I have a Asus laptop, and have been tring to install MacOS, but the installer keeps freezing arround 19 minutes remaining. I have already try without the samsung ssd that i have and also try with only one stick of ram.
Here is the logs of the installer:
The video was from a offline intaller, but with the online installer keeps making the same thing.
Laptop Specs:
MainBoard: Asus X530FN
Processor: Intel Core i7-8565U @ 1.6GHz (Whiskey Lake-U)
Graphic:
Intel UHD620
Network:
Wifi: Intel 8265 M2 NGFF (802.11 AC (2x2))
Bluetooth: Same as the wifi card
Ethernet: No
Audio: Realtek ALC256
Touchpad: ELAN 1300 (I2C)
Storage:SSD Samsung M.2 128GB
Keyboard: Chiclet keyboard
Card Reader: microSD CardReader
WebCam: VGA Web Camera
Battery: 3 Cells 42 Whrs Battery
Laptop Specs:
Graphic:
Intel UHD620
Network:
Ethernet: No
Your config.plist is not as per the guide.
Also, what's the exact model of your Samsung boot drive?
I have made the config.plist as per the OpenCore guide, but I will try to remake the file. And the SSD is a PM961but is already out of the laptop
After remake the config.plist as per the guide, the installer still having the same behavior.
Ensure the config.plist is the revised one and not the previous one. It seems like you have attached the previous one. Double check.
That last config.plist is the revised, the newhave most of the disabled deleted, as per the guide, and the acpi's ans kekxs on order. The only thing that is the same is the kexs, because i need this kexs to the laptop to works as intended
It is not as per the guide. Please provide the revised config.plist/EFI.
Here are a few issues:
Remove SSDT-EC.aml and replace it with SSDT-EC-USBX.aml
Remove SSDT-AWAC and replace it with SSDT-AWAC-DISABLE.aml
Why are you using EnableWriteUnprotector and RebuildAppleMemoryMap together? Use the latter one.
You should consider removing all the extra kexts except for the mandatory ones.
Why are you using XhciPortLimit when you have the USB ports mapped?
Also, it could be likely possible that this Laptop has NVRAM issues so better to use SSDT-PMC.aml. In addition, if you don't have the offline installer, use the online recovery method to install.
I was using the USBX, but have renamed the file
What's the diference between the 2 files, because on the OC page only refere to SSDT-AWAC
I have forgot to disable the EnableWriteUnprotector
On the video guide, isn't mentioned to not enable the XhciPortLimit if the ports are mapped
I have redone the config.plist, and now it crash during the boot, and showing this message: 20250222_014621.jpg
Its about official release and custom made.
Cause, the guide is outdated and at that time, the XhciPortLimit quirk was broken.
Are you trying to boot the installer or booting to the installed disk?
Also, attach your complete EFI. Just config.plist isn't enough!
ilikeeatingpeeandpoo
