Asus Zenbook 15 OLED UM3504DA
Ezekieel
ASUSTeK Computer - UM3504DA (FP7) - AMD - Ryzen SOC
AMD Ryzen 7 7735U with Radeon Graphics
ATI - AMD Radeon Graphics - 1002-1681
Hi, i'm new to Hackintosh and i try to install macOS Sequoia.
This is my Laptop :
─ CPU
└── AMD Ryzen 7 7735U with Radeon Graphics
├── Cores: 8
├── Threads: 16
├── SSE: SSE4.2
└── SSSE3: Supported
─ Motherboard
├── Model: UM3504DA
└── Manufacturer: ASUSTeK COMPUTER INC.
─ GPU
└── AMD Radeon (TM) Graphics
├── Device ID: 0x1681
├── Vendor: 0x1002
├── PCI Path: PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x0)
├── ACPI Path: \_SB.PCI0.GP17.VGA_
└── Codename: Yellow Carp
─ Memory
├── MT62F1G32D4DR-031 WT (Part-Number)
│ ├── Type: Unknown
│ ├── Slot
│ │ ├── Bank: P0 CHANNEL A
│ │ └── Channel: DIMM 0
│ ├── Frequency (MHz): 6400 MHz
│ ├── Manufacturer: Unknown
│ └── Capacity: 4096MB
│ ├── Type: Unknown
│ ├── Slot
│ │ ├── Bank: P0 CHANNEL B
│ ├── Type: Unknown
│ ├── Slot
│ │ ├── Bank: P0 CHANNEL C
└── MT62F1G32D4DR-031 WT (Part-Number)
├── Type: Unknown
├── Slot
│ ├── Bank: P0 CHANNEL D
─ Network
└── MT7922 802.11ax PCI Express Wireless Network Adapter
├── Device ID: 0x0616
├── Vendor: 0x14C3
├── PCI Path: PciRoot(0x0)/Pci(0x2,0x2)/Pci(0x0,0x0)
└── ACPI Path: \_SB.PCI0.GPP6.WLAN
─ Audio
├── Realtek ALC294
│ ├── Device ID: 0x0294
│ └── Vendor: 0x10EC
└── RV635 HDMI Audio [Radeon HD 3650/3730/3750]
├── Device ID: 0xAA01
└── Vendor: 0x1002
─ Storage
└── SOLIDIGM SSDPFKNU512GZ
├── Type: NVMe
├── Connector: PCI Express
└── Location: Internal
And here it's my EFI : https://drive.google.com/file/d/1mdnnl2WfHdnwIrZiin3pw9o4JSwJS5vy/view?usp=sharing
I've try multiples guide such as : https://dortania.github.io/OpenCore-Install-Guide/ or
/ https://elitemacx86.com/threads/how...ncore-uefi-legacy-opencore-install-guide.950/ .
The process go on and black out and restart after 10-15 second as you can see here :
And here it's log from opencore : https://drive.google.com/file/d/1yAi1uQ64FkjzBA9OdcbwlS_1ifNtfuJl/view?usp=sharing
Can you help me to see what's going on bad ?
Thx in advance.
This is my Laptop :
─ CPU
├── Cores: 8
├── Threads: 16
├── SSE: SSE4.2
─ Motherboard
├── Model: UM3504DA
─ GPU
├── Vendor: 0x1002
─ Memory
│ ├── Type: Unknown
│ ├── Slot
│ ├── Type: Unknown
│ ├── Slot
│ ├── Type: Unknown
│ ├── Slot
├── Type: Unknown
├── Slot
─ Network
├── Vendor: 0x14C3
─ Audio
├── Realtek ALC294
└── Vendor: 0x1002
─ Storage
├── Type: NVMe
Thx in advance.
Ryzen 7735U APU isn't supported as of now.
I've succeed for now to access to the "installer menu" of Mac Os but can't download because he didn't recongnised my wifi card. So i've try to make a "offline installer", it was really difficult to find how to without mac but i've succeed to do so with a Virtual Machine working and my usb key plugget into Virtual machine.
Now i'me facing other issues. Os installer launched when it's "online method" so with baserecovery.dmg but can't install it because of wifi card undetected.
Os installer didn't launch when i use the "offline method". I use the exactly same EFI for both. So there is my questions :
Is there a difference about ACPI / KEXT etc... between "offline method" and "online method" when we try to install Mac os ?
Other question, do you think that is good idea to try on Sequoia or should i try on another OS ?
And also you should know that my goal it's just to install mac os on my computer to learn, not looking to have "perfect hackintosh".
By the way i've order a ax210 wifi card to try to make it work with "online method".
Even if you manage to install, it isn't worth as the acceleration won't work and it will have the same performance as VMware and Virtual Box. If that's what you want, you can surely go ahead.
kocsik
