SOLVED Fenvi FV T-919 Bluetooth only working
swixiiii
Gigabyte H410m V2
i5-10400f
Sapphire Radeon RX 570 8gb
Hello, I’m new to hackintosh and I used Sonoma for my first one. I bought a fenvi fv t-919 and only bluetooth is working. I followed tutorials but nothing is working. Can someone help me please?
Here's my EFI, please help me i've been searching for one week but every solutions aren't working.
Have you mapped your USB Ports?
Yes but I don’t think I’ve done it well, the problem is that I can’t root patch because SIP booted : 0x803 / expected : 0xa03
Then you to check the STEP #7:
Nothing is working even with step 7 View attachment 8958
The boot arg you have is wrong.
Its "amfi=0x80" without the quotes. You have amfi in uppercase which makes the boot arg invalid. Always remember that the boot args are case sensitive. In addition, refer to the original guide for patching. You probably, wouldn't need the other arg. Just amfi=0x80 should be sufficient for patching the WiFi.
Sadly it doesn’t work too…
Here's my EFI folder. Hope it can help you.
OhCamargo
