Installing MacOS High Sierra Stuck on Apple Logo with progress bar, Mouse Showing.
bossoy54
HP Motherboard
i7-8700
GTX 1070/Intel HD Graphics 630
10.13.x
PC: HP Omen 880-p1xx
CPU: Intel Core i7-8700
GPU: Intel HD Graphics 630 / GTX 1070
RAM: 32GB
I have this issue where when i boot from the USB Stick that i created and click on "Install High Sierra" from the usb boot menu it loads like the codes and then i come to the apple logo with the stuck progress bar it just gets stuck at 10% from what i guessed how it looks. Sometimes i get in to the "MacOS uttilites Menu" where i can select disk uttilities and so on but there it freezes aswell it kinnda blends the apple logo with the Utilitie menu seems like a graphic glitch?? Tried it with iGPU and Normal GPU but same issue the mouse is Showing i can Move it aswell. Any help would be appreciated. I used a premade EFI Made for my cpu Codename: Coffee Lake from olarila.com installing-macos-high-sierra-stuck-on-apple-logo-with-v0-tl61fazniy9e1.png
RAM: 32GB
I have this issue where when i boot from the USB Stick that i created and click on "Install High Sierra" from the usb boot menu it loads like the codes and then i come to the apple logo with the stuck progress bar it just gets stuck at 10% from what i guessed how it looks. Sometimes i get in to the "MacOS uttilites Menu" where i can select disk uttilities and so on but there it freezes aswell it kinnda blends the apple logo with the Utilitie menu seems like a graphic glitch?? Tried it with iGPU and Normal GPU but same issue the mouse is Showing i can Move it aswell. Any help would be appreciated. I used a premade EFI Made for my cpu Codename: Coffee Lake from olarila.com View attachment 8865
As the EFI is not attached, no idea what could be causing the issue.
What is the disk model installed? The NVMe.
Hello, So i decided to switch to high sierra and sucesfully installed it on my Hard Disk Im using a HDD! Yesterday it was fine however today i cant run macOS anymore because when i launch it from the usb stick i come to the section of the opencore boot picker i pick macOS and then it loads but then kernel panics i attached the log and the EFI below. Note: This time i decided to write the config.plist myself.
And something i forgot to mention whenever i plug my iPhone in to the pc in macOS it dosent get detected dosent even charge i did the usb mapping in windows before i installed macOS.
And also whenever i plug my iPhone in to the pc in macOS it dosent get detected dosent even charge i did the usb mapping in windows before i installed macOS.
You shouldn't require FixupAppleEfiImages.
When you map the ports, you should no longer use USBInjectAll.kext.
Enable UnblockFsConnect
Oh alright then, thank you so much will try it when i get Home also do i delete the USBinjectAll After installing macOS? Thank you for your help.
Oh nvm i understand now
Alez0903
