Reboot without errors
Yuzuru
Nitro V15
Ryzen 7 7735HS
Radeon 680M / RTX 4060 Mobile Max-Q
15.x
Hello everyone, the laptop I use is Acer Nitro v15 and its specs are;
CPU: Ryzen 7 7735HS
Graphics Card: Radeon 680M / RTX 4060 (I know that amd gpus is not supported, I will use it for testing purposes while adding support to the nootedred kext)
Memory: 32 GB DDR5SSD: 1 TB Kingston Nvme
The way that I don't understand instead of booting it is automatically restarts my system even though I am using keepsym arg ,
I created the ssdts using ssdttime maybe that could be the reason but I don't think so
I am attaching my latest open core log file and efi folder, I would be very happy if someone helps.
Edit: I messed with up a little bit and changed various things and it now displays `Still waiting for dsmos to arrive` with a crippled text and gives kernel panic , and again I couldn't understand anything from the log so here you go.
CPU: Ryzen 7 7735HS
Seems like there is a possible KP.
When you know that the 680M isn't supported yet, what's the purpose? The system will be extremely laggy, will become unresponsive from time to time. It would be better to use Virtualization for such purposes.
Your EFI is not as per the guide. Here are a few issues:
Remove SSDT-EC and USBX and use SSDT-EC0USBX-DESKTOP.aml
Remove SSDT-CPUR and add SSDT-PLUG-ALT.aml
Why are you using EnableWriteUnprotector and RebuildAppleMemoryMap together? Use the latter one. If it does not boot, use the prior one. You must use only one, not both together!
You should also remove the miscellaneous kexts. The goal should be to have the minimum set of required kexts to boot the installer.
Remove NootedRed.kext. There is no support for 680M and using the kext can cause KP.
Have you mapped the USB Ports on your own?
Ryzen 7 7735HS is an 8C, 16T CPU. No idea why you use 6C in the Kernel Patch.
Also, you gotta remove the Ps2KeyboardDxe and Ps2MouseDxe drivers from UEFI>Drivers section
felipepedrosa
