- Nov 29, 2024
- Nitro V15
- Ryzen 7 7735HS
- Radeon 680M / RTX 4060 Mobile Max-Q
- 15.x
Hello everyone, the laptop I use is Acer Nitro v15 and its specs are;
CPU: Ryzen 7 7735HS
Graphics Card: Radeon 680M / RTX 4060 (I know that amd gpus is not supported, I will use it for testing purposes while adding support to the nootedred kext)
Memory: 32 GB DDR5SSD: 1 TB Kingston Nvme
The way that I don't understand instead of booting it is automatically restarts my system even though I am using keepsym arg ,
I created the ssdts using ssdttime maybe that could be the reason but I don't think so
I am attaching my latest open core log file and efi folder, I would be very happy if someone helps.
CPU: Ryzen 7 7735HS
