Cant boot the EFI (got to a kernel panic)
d0mkaaa
Asus Prime B450M-A II
AMD Ryzen 5 5500
AMD Radeon RX 6600
Hi, so I just made an EFI using EliteMacx86 tutorial for AMD platform, but when I try to boot the EFI in OpenCore boot menu, it just aborts and shows me a apple sign that it can't and a link to apple.com/mac/startup
OpenCore version: 1.0.2
edit: I updated config.plist like the boot args and etc but now I got to the point it just gives me kernel panics.
What macOS version are you trying to install?
I already fixed the problem its cause I used a configurator using your tutorial and got told not to use it.
Glad its fixed. Which tutorial did you follow?
nnaa
