Try to go from oc to unstaller dmg but get verbose and restarts back to OC menu + resetting nvram unmounts oc efi :(
AMDAzure
Lenovo IdeaPad 3/hp eq0007au
Ryzen 3 3250u/3200u
integrated vega 3
11.0.x
This is my second hackintosh attempt on a simillar spec lenovo ideapad slim 3 with a ryzen 3250u.....
I have made efi and config.plist following the EliteMacx86 amd laptops guide for sonoma
i have used same ssd on an hp laptop with bascially same specs and it was succesful
but on this lenovo pc it is a pain to get the EFI loaded to the bios ( i use BOOTICE FROM WINDOWS TO CREATE BOOT ENTRY EACH BOOT IF I TRY AND RESET NVRAM)
upon pressing enter on the dmg file from oc, it takes a while to load the verbose and it stays on for a few seconds and proceeds to go away and restarts my pc to oc menu, and time period is so short i cannot possibly capture what error/message it gives pre-restart, i will try to attach a video
both the issues have terrorized me for hours please helppppp :((((
i feel like i didnt highlight the boot entry issue well: so, whenever i try to boot form a pendrive/partition my bios does not recognise the bootx64.efi file so i have to create a boot entry using BOOTICE, it boots to oc normally, but upon trying to reset nvram it clears the boot entries for OC and instead normally boots to windows causing me to repeatedly make an entry......
The video is corrupt and the guide does not include BOOTICE. So, that step is totally wrong. List the system specs.
ill try reuploading the video, but i had to take the bootice step myself, as without it i wouldnt be able to reach even opencore, and it has no effect on oc or the efi, just feeds to bios about booting from OC and and not windows boot manager
(attaching a frame from the video i took showing a bit blured panic with something about nred)
my specs are the same for lenovo ideapad as mentioned in profile :)
ill try reuploading the video, but i had to take the bootice step myself, as without it i wouldnt be able to reach even opencore!
Attach the EFI you're using and please post the specs here for secondary system. Only primary system specs should be included unless you want to change it to the system specs, you're seeking support for!
Lenovo IdeaPad slim 3 with: AMD 3250u (apu), 8gb RAM, 256 gig KIOXIA HP manufactured SSD, MediaTek soundcard, Realtek 8822CE Wireless WiFi card
Might be an accident, which one should I be using?i
xxxxxxxxxx
