Hello I have a question does my SSDT-Bridge.aml appears to be incorrect? If not; why does my mac is not able to recognize that one of my 2 pci lanes is being in use from gpu (rx 580)?
-Thanks in advance.
  • SSDT-Bridge.aml
    SSDT-Bridge.aml
-Thanks in advance.
The 580 seems to be used. What's the issue here?
Reactions: Poseidonios
Hello thank you so much for your time! My main goal here is to make the system recognize the usage of one of the x 2 pci slots.
For example in the system settings if I click on the PCI Cards the system will not recognise that the rx 580 is been in use.
For my limited experience; will I be able to fix it if I compile the SSDT-GPU-Spoof inside the SSDT-Bridge?
-Once again thanks in advance
Oh, to make the devices appear in System Report>PCI, you need to define the properties either via the Device Properties or SSDT.
Yes, if the SSDT is loaded.
I changed the SSDT-GPU-SPOOF.aml file to spoof the
PolarisRX580 2048sp6FDF67DFSpoofs as AMD Radeon RX570/580
it compiled with no errors.
Suddenly out of nowhere a second file is mentioned, namely SSDT-DTGP.aml. I can't find it anywhere, there's no download link. Should I just ignore it? Will the spoof work as advertised without it? I'm on Mac OS Monterey.
Try the attached file and load it prior to the SSDT-GPU-SPOOF.
alvarg82
