thank you so much! Thanks to your tutorial I was able to install mac os I was able to install mac os monterey on my alienware 15 r4 with a gtx 1080 because it does not have a mux or nvidia optimus chip. According to the diagram, the graphics card is connected via PCIe to the processor. The system is relatively efficient. The problem is that when I open final cut, the program closes and the error window appears and when I open Photoshop or any program that requires power from the video card, it renders as if it didn't have it. Is there any solution for it?View attachment 7171
That's because there is no metal, just OpenCL. However, will check at our end.
Unfortunately my rx6950 had issues so it's in RMA now. In the meanwhile i put into my hackintosh (Ryzen 9 7950X) my old Nvidia GTX680. I removed spoof from config and system starts but with no acceleration. With OCLP i applied patches to nvidia drivers and everything is ok but when i reboot after patching osx reboot my system every time.
This happen both with Sonoma or Ventura or Monterey.
Check if the SecureBootModel is Disabled.
can nvidia 940mx can work on mac os?
i have a GTX 1050ti for my desktop will it work with this tutorial?
Write your reply...
daemon6109
