Tried too much, but graphics not working
ready2000
MSI MAG MORTAR MAX WIFI B550M
RYZEN 5500GT
RTX 3050 INNO3D 8GB
15.x
Hello, it's the same laptop
Lenovo ideapad 520 15ikb
Intel 8250U with UHD 620 Kaby lake R + nvidia mx 150
It's the same efi as last attached in thread well still cannot install except that i added patch as in image.
Upon bbooting, I get a black screen after macos logo. There is backlight, but no output
I hhave tried all flags like -igfxblr -igfxonln=0 igfxdvmr (something like that) and what all i could find in whatever green guide. Nothing works. Backlight is there but black screen. Need help.
IGNORE that ! on top it's just I opencore not updated in ocat nothing else. Just cuz I redownloaded itit to click a pic. Otherwise I'm using updated ocat only to edit all the files.
Please attach the EFI to check!
Here.
Note I have tried igfxblr, igfxonln=0, igfxmetal=1 ONLY as of now. No luck. Black screen after boot.
Without the patch (in DP), i get Display without acceleration (7mb). Processor is Kaby-Lake-R with UHD 620.
I have seen a very similar thread in ur website where the person couldnt resolve the issue and u recommended EDID (something like that) 😭. I really need grafix dude pls help.
FOr other person, he just bought a macbook (WTH 😭). Its the same Processor with same igpu 8350U+UHD620. Do u think it will ever work? 😭
Here.
There are no connectors defined so black screen after boot is expected.
See connector patching:
In addition, remove -igfxblr and add -igfxblt. You'll also need to remove
Also, why is the SIP modified and you have added amfi_get_out_of_my_way=0x1? Don't say you used OCLP.
Lastly, what macOS version you have installed?
Hahaha, I spoofed my Intel Wifi card as brcm that applied OCLP. Then disabled the fake entry and loaded Airportitlwm for Ventura. This worked like a charm and Intel wifi is working at full speed natively :)
(Saw this workaround at github)
Yes, that's also one of the method.
macOS Sequoia 15.0 (From official Olarila Vanilla Sequoia image)
Also will read the guide and do as u said
Ignore. typo. Make the changes and attach your EFI to check.
Reactions: ready2000
Hi, I hope it will be fine if i do this after few weeks... due to some issues I can't do this rn, but will do soon!
Not a problem!
Listo
