SOLVED ☠️☠️Well, Booting stuck in b/w
Yes, use the flags for the initial phase.
Show the option and what do you mean it corrupted the card? Which card? What corrupted it?
ok so I added -wegnoegpu and now system boots well. I did not disable Airportitlwm and it doesnt cause any issue. I can see the wifi icon. But now I have a problem that I cannot see anyything there. It is blank. Can you tell me how to get it working? I need that for installing. Please help. Should I add IO80211Family.kext?
Reactions: ready2000
There were some more issues that I cannot install but okay opening a new thread.
You may close this threaad
NCC74656
