SOLVED ☠️☠️Well, Booting stuck in b/w
ready2000
MSI MAG MORTAR MAX WIFI B550M
RYZEN 5500GT
RTX 3050 INNO3D 8GB
15.x
Hi there once again,
As uk, I'm trying to install macOS on my Laptop with following specs:
NVIDIA MX150
Intel i5-8250U with Intel UHD 620
Lenovo Ideapad-520 15IKB 81BF Laptop 8GB RAM 512GB SSD (SATA) , 1TB HDD
EFI attached, Video Link where it stucks:
Tried enabling and disabling Whatevergreen, no luck. Made EFI using your guide. I am booting macOS Sonoma recovery method.
NVIDIA MX150
No EFI attached. Disable the IGPU using -igfxvesa flag and it should be able to boot.
omg sry donno how it wasnt attached, attaching here, will post update by adding that flag
Ok so it's been a long time and it is stuck here now
Why WEG is disabled? And why -igfxvesa is not added?
Remove AirportItlwm.kext first
Disable NVIDIA GPU and hopefully, it should boot.
How do i disable the GPU? -wegnoegpu? SSDT-DISABLE-GPU?
I HAVE bios option also but that almost corrupted the card that i couldn't use it again in windows for weeks.
Yes, use the flags for the initial phase.
Show the option and what do you mean it corrupted the card? Which card? What corrupted it?
imadeocy
