Start image failed
Still facing this problem when installing ventura and sonoma using the recovery file
Also facing the problem “image startup failed” when trying clean install sequia
This indicates a KP and is a different issue than the original thread. Try to install Ventura and you should be good. Attach the verbose video to check.
Try to install Ventura first as that's natively supported on your Laptop.
where can I get the verbose video?
Just add -v to the boot args. Boot via installer. Record a video using your phone and send it over here.
This is the EFI
However, I've found an EFI online and using it doesn't trigger KP issue. Apparently, when booting using this EFI.. It stuck on the apple logo, do you know what issue is that? I can't attach the EFI file here bcs its to large, do you mind if I email u personally?
sammrafi
