Sequoia installation error after booted to recovery
Vish877
DELL vostro 3471 motherboard with b365 chipsest
intel i3 9100
Uhd 630
15.x
During mac sequoia installation it say An error occured preparing software update . How to fix this error? The log is provided.
Attach the EFI you're using to boot
How come 9100 is installed on a Laptop? 9100 is a Desktop CPU
Thanks for your support. I have doubts about whether creating the EFI according to this video will help solve the issue. I built and patched the ACPI in the old EFI, but this video uses pre-built ACPI. Will that work?
Thanks for your support, I have doupt creating efi according to this video help to solve this issue or not and I builded the acpi and patched it in old efi so when come to this video it use prebuild acpi so it works or not
Can you rephrase it for me?
gopon_user
