CPU Compatibility List For macOS [Intel/AMD]
Hi I have this Windows 11 PC and I want to dual boot with MacOS, is my hardware compatible with Sonoma, or what version do I need to install?
HP Envy 750-113D
CPU - Intel Core i7-6700
RAM - 32GB
GPU - Nvidia GTX 960
SSD - Crucuial P3 (1TB)
HP Envy 750-113D
RAM - 32GB
Hello,
SKL support has been removed since Ventura. However, you can spoof it to KBL and can install Ventura or later. If you want to have native support, Monterey would be the maximum version.
Hello, I had a new ryzen7 7730u with Vega 12. Has codename Barcelos but it's Cezanne architecture. You think that can install Mac on it?
Yes, you can.
Hello there i have a problem when tryin to install macos, where it says that is not compatible for my board, i have a Mother board Tuf b450m-PLUS with a Ryzen 7 5700g using the apu, am i doing something wrong or its not posible, ive tried from high sierra to monterey with no luck, any clues?
The CPU is compatible. Please create a separate thread for the installation issues.
Reactions: Alexandeer
Hello, I have a Lenovo Thinkpad L14 with 7730U and have difficulties to create an EFI. I would like to keep the laptop for a longer time but unfortunately I can't get a running EFI. Can I get help here if I upload my config.plist or the whole EFI?
I have done it according to this guide
but no chance, I can't get it to run
Attach the EFI you're using.
adamnor206
