Hello everyone!
ilsimi
Beelink SER5 Max
amd 5800H
amd 5800H
  1. MacBook Air
Hello everyone 🙂I am thrilled by the idea of running MacOS on my PC hardware. I am a total noob, but I managed to run MacOS Sonoma 14.1 on my Beelink SER5 Max hardware. However, is not running smoothly, and bluetooth not working. I am here to learn how to fix this, and I am sure I will find help!
Best,
Simon
Edit: I am using exactly this EFI specifically, which seems tailored for my machine (I have exactly the same hardware): https://github.com/daliansky/Beelink-SER5-Hackintosh
Bluetooth is sometimes working sometimes not, the system has accelerated graphics and the performance looks fine until it freezes for few seconds and then is smooth again, then randomly freezes again, and then smooth again.
Moreover, sometimes I get random reboots out of the blue.
Do you think those issues are fixable? or am I pretending too much?
Thanks
Did you solve it? I have the same problem, I'm using the same EFI
Best,
Simon
Thanks
Attach the EFI you are using!
EFI here: https://github.com/raphaelfuchter/BeelinkSer5-hackintosh/
(I couldn't attach it directly here)
Same hardware.
Specs:
Model:Beelink SER5 Pro 5800H
Processor:AMD Ryzen 5 5800H (8 cores / 16 threads)
Integrated Graphics:AMD Radeon Vega 7
Memory:Crucial 16 GB (2x 8GB) @ 3200 MHzOperates @ 3200 MHz 22-22-22-52
Storage:Kingston NV1 500 GB M.2 NVMe SSD (PCIe 3.0 2280)2.5" SATA HDD slot
Audio:AMD Radeon HDMI Audio (K19.5)Realtek ALC 269
Connectivity:2x HDMI 2.01x Headphone jack1x 1 GbE LAN3x USB 3.2 Type-A1x USB 2.0 Type-A1x USB 3.2 Type-C (data + display)
Communications:MediaTek RZ608 Wi-Fi 6E 2x2Bluetooth 5.21x Realtek RTL8168/8111
Same hardware.
Specs:
How much is the VRAM? Check from AMD Control Panel in Windows.
I don't have Windows, I just have Mac installed. Is there any way to check this on Mac?
None that i'm aware of. You can use a external medium to run Windows to determine the VRAM.
In the BIOS the information appears as 3G
The BIOS is different. It shows how much you allocate. You need to use AMD Control Center to validate the same information.
kod_mic
