SOLVED PC won't boot newer macOS versions than macOS Ventura
Marcus
Asus Tuf Gaming a520m plus II
AMD Ryzen 5 5500
Nvidia Geforce GTX 1660ti
Hello guys
I wanted to install macos sonoma on my computer as a hackintosh but it doesn't boot from the installer. I've made the installer new several times but it doesn't work. All of the other macOS Versions which are older are running fine but macOS Sonoma and newer not. I can't find the issue. Thanks for your help.
Hello guys
Attach the EFI you're using to boot
This is the EFI I'm using to boot
When I'm going to boot macOS Sonoma or higher from the installer I become this error. IMG_0002.JPEG
I enabled SetupVirtualMap in Boot -> Quirks but it doesn't work. It has the same error then before.
Attach your BIOS Settings.
The problem has just been solved. I just found out that my RAW image was broken and my computer couldn't boot. But still thank you very much for the help.
Glad its solved.
Marking Solved and closing this thread.
rbrb
