SOLVED [Help] macOS not shutting down correctly
Dumped using SSDTTime
Did you disabled the addons SSDTs? If not, its not native dump.
Secondly, attach Hackintool PCIe info+IOReg
I did the dump while in WIndows, so no addon SSDTs were enabled.
Attached PCIe info and IOreg
I forgot to mention, I keep my system updated.
So I’m on macOS Sonoma 14.5 and OpenCore 1.0.0
I managed to fix the issue.
I fixed the DMAR table (not sure if it's related to the fix), then added SSDT-DTGP to my EFI (with the correct Thunderbolt hotplug fix SSDT already present). That fixed it, and now it shuts down correctly.
Glad to hear!
Closing now
felipepedrosa
