SOLVED When I enter NootedRed Kext MacOs no longer starts up
pietronizzardi
MSI B450 GAMING PLUS MAX
Ryzen 5 3400G
Radeon Vega 11
  2. OpenCore (UEFI)
  1. iMac Pro
I did the EFI creation of my AMD Desktop (you can find it attached)
CPU: AMD Ryzen 5 3400G
RAM: 16GB 3200Mhz
MOTHERBOARD: MSI B450 Gaming Plus Max
by following the following video
When I tried to do the installation, I noticed that I could not get to the installation screen because of the NootedRed kext. In fact by removing it I was able to do the installation and do the Ventura setup. After I put the EFI in the disk I try to add NootedRed by following this video
but after I add this kext, at MacOs startup white writing appears and it reboots and repeats like this endlessly.
This is what happens when I try to start mac os (after doing nvram reset),
View attachment VID_20240704_2045583.mov
I cut the video but I kept it up like this for 5 minutes to make sure that macOS wouldn't start up
What can I do? I would like to use MacOs only with APU and this kext does not work. I have checked the bios and everything is plugged in fine
IMG_20240704_204317.jpg IMG_20240704_204326.jpg IMG_20240704_204333.jpg IMG_20240704_204349.jpg IMG_20240704_204517.jpg
Please help me, thank you
EDIT:
I'm looking at the guides, maybe I need to spoof the gpu?
RAM: 16GB 3200Mhz
View attachment 7982View attachment 7983View attachment 7984View attachment 7985View attachment 7986
EDIT:
Do NOT use npci flag with 4G Decoding Enabled. Try the latest commit for NootedRed and then check.
And no, spoofing is not needed in your case.
NON usare il flag npci con 4G Decoding Enabled. Prova l'ultimo commit per NootedRed e poi controlla.
E no, nel tuo caso non è necessario ricorrere allo spoofing.
where do I find the latest NootedRed commit?
I just tried as you say, Mac OS doesn't start. I did as you say in the video, I modified the config (you can find it attached) and on reboot I did NVRAM reset and started macos, but as you see it does not start
Attach verbose video.
Seems like its VRAM issue. Set Integrated Graphics to Enabled and try to increase the VRAM to 2GB.
I thank you!!! it worked!!! I only have one doubt, why doesn't it recognize the processor?
xmax114
