Thanks for your reply:).
I am using BigSur.
Processor Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
Adapter Type NVIDIA GeForce GTX 1060 5GB, NVIDIA compatible
I am still not sure whether it is possible or not.
According to "AMD compatibility list for Mac OS" RX6950XT support starts from MacOS 11 Big Sur. So if there is a way to get RX6950XT to work with OSX10.14 Mojave it is not only GPU SPOOF needed? Some kexts like nootRX or smth like that?
No, not at all. The driver support is absent prior to Big Sur. So, spoofing will not help!
Anyone having trouble with AMD RX 6950XT:
Please install Windows, it is the best easy way.
Do all your thunderbolt and AML and USB and all things with Hackintool, SSDTTime, and USBToolBox.
Use SSDTTime.
Use Windows device manager.
Go to the AMD RX 6950 XT. Find the location info. Input into SSDTTime for "Spoof" menu. The ID should be changed into 0x73BF for the 6900 XT
In Config, you must also change device-id to 0x73BF and you can adjust the name for aesthetic reason as well. I will post what my info looks like.
Use SSDTTime.
Thank you for notifying. Will include this method as well.
Reactions: longlongman
Honestly, @EliteMacx86 videos on YouTube are basic and good. Understanding is easy. (there are too many spoof files in the internet and cannot use those files, we should make own spoof file ALWAYS)
You can show Windows machine in YouTube? Please do this:
Making custom GPU spoof.
Windows working running OK.
Find GPU (6950XT) PCIE location in device manager.
Copy anywhere.
Open SSDTTime. Option "spoof hardware".
Paste ID from device manager for graphics card.
Because it is not native to macOS, it cannot find easy. We must bridge the device. I think 6000 series AMD GPU always has bridge. We must do this.
Also fake device ID to 0x73BF !!!
Write into PLIST file information.
After, it works perfect.
Suggest your video about disable ULPM and 0fan because it is the best.
Copy anywhere.
Thank you for your kind words!
Yes, from 5000 series onwards, a bridge device is needed.
Copy anywhere.
I'm confused... SSDTTime does not have the option "spoof hardware"
Reactions: Brinary
alvarg82
