Not supported. Replace it with a compatible card instead.Is there a Realtek RTL8723AE kext ? If so, can you provide the link ?
You need to check whether your system has any kind of whitelist or not and what features you would need.ok,can I have the list please ?
Atheros is no longer preferred. You have two choices. Intel and Broadcom. If you don't have the use of AirPlay, Handoff and AirDrop, you can go for Intel. However, please note that speeds may fluctuate and it might cause issues. On other hand, Broadcom will work fine till macOS Ventura. If you plan to use macOS Sonoma, you'll have to patch the system.Are the two cards compatible?View attachment 7702
Yes, that's right!I want to take advantage of AirPlay, and AirDrop and especially the speed I'm on Ventura and I'm going to install Sonoma, so I buy Broadcom?
No. Not any. See the Compatibility list here:just one last question and I'll leave you alone, any Broadcom model works on hackintosh ?
elitemacx86.com
