Hi,
I followed the updated guide (21/04/24) but it did not fix the static noise issue on my jack headset, after some time the noise brutally becomes worse actually.
Details
- Audio Codec : ALC295
- macOS version/CPU/GPU:
- macOS Version: 14.3.1 (23D60)
- CPU: Intel i5-10300H (Comet Lake)
- GPU : Intel UHD 630 | Nvidia RTX 3060
- Copy of IOReg: (see iwissem alc295.zip)
- Method used for enabling Audio:
- Apple ALC.kext + layout_ID: 13 (specified with alcid=13)
- Installed CodecCommander.kext
- added to OC/kexts and enabled in config.plist
- Kextcache output (see iwissem alc295.zip)
my zip file is too heavy to be uploaded here (35mb) you can find it in my public repository here
Documentation/Audio research/
Is there any way to monitor the audio codec across events like before and after a sleep/wake cycle?
I am certain that the solution to my issue relies there.
