OkayI have a question !
Let's say the OpenCore EFI is successfully copied/moved to the HDD/SSD.
MacOS will launch from the HDD/SSD : ok.
Well, that's obvious because the Recovery is not using a different config.plist/EFI. As its booting from the same problematic one. So no matter whether you boot via main disk or the recovery or via a USB installer. As long as you don't correct the EFI or config.plist, it will not boot and problems are expected.After that, let's do some changes on config.plist, then after the reboot, the system crashes before the desktop.
Now, trying to boot with the recovery : it crashes too.
I mean : no more able to boot from the usb key, does not appear on boot menu...
How to fix that ?
NB : that happened to me twice (so far), and I found a way to recover, but a not-easy-one.
