Hackintosh stuck on apple logo
Demian-mac
AMD Radeon
AMD Ryzen 7 47000U
Maibook M
Hello! I've always wanted to install MacOS on my AMD laptop. I watched your video about setting up OpenCore, but when I download the installation, my computer gets stuck on the Apple logo. What should I do? IMG20240414104042.jpg IMG20240414104037.jpg
Remove the comma after -v and post the picture of the error.
Also, why are you using EnableWriteUnprotector and RebuildAppleMemoryMap together?
I followed in your footsteps, so to speak, corrected all the mistakes, but now a slightly different error. Some text appears for a while (see attachment) and then everything reloads. IMG20240421152216.jpg
I followed in your footsteps, so to speak, corrected all the mistakes, but now a slightly different error. Some text appears for a while (see attachment) and then everything reloads.View attachment 7450
What did you exactly correct? Attach the updated EFI.
Disable DevirtualiseMmio and then check.
If it fails, disable RebuildAppleMemoryMap and enable EnableWriteUnprotector.
Make sure to reset NVRAM a couple of times after the changes you make.
I tried to rebuild Opencore, but the same error occurred when booting. Maybe you will try to build an opencore for me yourself, because you have more experience in this business?
youseff
