Problem with instalation sonoma 14.3.1
adriano89
MSI Z790 MAG TOMAHAWK
i9-14900KF
Radeon RX 6600
Hello guys :)
Yesterday i try to instal sonoma 14.3.1
I made a botable flash drive with the installation of sonoma (OpenCore) method, I started the installation, everything was going well until the black screens the installation would not stop, every time I want to install I have a black screen, sometimes after 15 minutes something moved and I could go to the next stage of the installation of sonoma but in the end I failed to install, I managed to take a picture of some error that may be the cause of the black screen, can someone help please? I attach the photo of the error. Maybe somone knows how to solve this.
Thank you 🙂🤛
Hello guys :)
Thanks you 🙂🤛
What NVMe are you using?
samsung 980 pro 1tb
samsung 980 pro 1tb
You think this error can be beacuse of this ssd? Generally it happens when i choose on boot menu partition with sonoma when i press it, the load white subtiles, and after this i get black screen and computer reboot. Also when i have insalation. I would like to add that during the installation that the screen goes to the standby state and after 5-7 minutes it turns back on again. This hakintosha kill me inside 😭😭
I successfully installed sonome on this drive, but the problem of resets continues this time when I reboot os system, the same situation happens as when installing. The computer reboots with "100" times to get the system to load, of course I replaced the EFI folders with my configuration. This is restart loop on attempt to startup...
Can you explain it more clearly?
Write your reply...
イツミてんちむデモン(Real_That_Itsu
