Can I spoof the internal graphics of the Ryzen 9 6900HX, i.e. Radeon 680M, differently?
At least I made it to the Farife interface, but no graphics acceleration. With or without WEG and NootedRed and matching SMBIOS, the mouse only moves after 20 seconds!
No, that will not work. Spoofing does not mean that it will be supported on any unsupported architecture. Spoofing has limitations. Read the guide carefully.
Reactions: karatasios
What original and spoofed device ID should I put for Radeon R9 270X? (I fixed the problem that my computer restarted because of a problem)
I can make my NVidia Geforce GTX 1060 enable but still lacks metal support. How can I do?
6810
This guide is about Graphics spoof. What macOS version are you using?
Thanks for your reply:).
I am using BigSur.
Processor Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
Adapter Type NVIDIA GeForce GTX 1060 5GB, NVIDIA compatible
I am still not sure whether it is possible or not.
Where can we find SSDT-DTGP.aml?
OpenCore-0.9.9
xxxxxxxxxx
