Fujitsu Lifebook u727 - need help with Elantech PS/2 Touchpad
u727
Hi,
I am new in OSX
I use a Fujitsu Lifebook u727 with 14.3.1 have trouble with the Elantech Touchpad.
If I boot a live Linux I can see that it is a PS/2 Version.
[ 2.740418] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio2/input/input8
14.3.1 is running but the Touchpad did not work... all other works OK
Using OpenCore 0.9.8 and did a bit update of this EFI
from this gitrepo https://github.com/shirokun20/Hackintosh-Fujitsu-P727-Lifebook
If I change the Version of VoodooPS2 the keyboard did not work.
Or if use this Version: https://github.com/BAndysc/VoodooPS2/releases/
then I got a boot loop
I need help to fix this issue - but explain in detail please ( I am a absolute beginner )
Hi,
I am new in OSX
The first thing you should do is to create a proper EFI.
@EliteMacx86
ok thanks.... all works except for the touchpad
I will try to build a new EFI
@EliteMacx86
I tryed but got only a "support.apple.com/mac/startup" message
did not start booting
CPU: i5-6200U
GPU: Intel HD 520
xmax114
