ASRock B760 Pro RS/D4 works perfectly in Sonoma but Radeon Pro W5700 has problems!!!!
i5-13400F
Radeon Pro W5700
  1. Mac Pro
Hardware:
CPU intel i5 13400F
RAM 2x 16GB DDR4 (2800MHz)
SSD 980 512GB NVMe gen.4 x4
WIFI/BT PCIe: Broadcom BCM43xx / BCM_20702B0
https://www.amazon.it/dp/B081CFM2J4?tag=tonymacx86com-21
GPU: NITRO+ RX 580 4GB GDDR5
GPU: RadeonPro W5700
boot-args: -ctrsmt alcid=98 agdpmod=pikera debug=0x100 keepsyms=1 revpatch=cpuname,sbvmm amfi=0x80 -v
Works perfectly in macOS Sonoma 14.4 (EFI OC attached):
hotswap SATA OK
TRIM SATA SSD OK via terminal ''sudo trimforce enable'',
USB2/3 OK
WIFI/BT OK
Ethernet 2,5Gb OK
Everything works and is extremely stable but when I updated the video card to the Radeon Pro W5700 it crashes at startup (photos attached).
Works only in "-x" boot mode!!!!
THE VIDEO CARD is new and DOES NOT HAVE ANY DEFECTS AND WORKS PERFECTLY IN WINDOWS 11 PRO
I can't find a solution!!!!
can you help me?
  • EFI.zip
    EFI.zip
Hardware:
CPU intel i5 13400F
hotswap SATA OK
USB2/3 OK
WIFI/BT OK
Ethernet 2,5Gb OK
can you help me?
Secondly, you should not use ResizableBAR. Disable it using -1.
Remove RadeonSensor and SMCRadeonGPU.kext.
Listo
