GUIDE How to Fix Broadcom Ethernet on macOS [Clover/OpenCore]
How to Fix Broadcom Ethernet [Clover/OpenCore]
This guide is about fixing Broadcom Ethernet chips on macOS using Clover or OpenCore.
Supported Chipset
  • BCM5722
  • BCM5754
  • BCM5754M
  • BCM5755
  • BCM5755M
  • BCM57788
  • BCM5787
  • BCM5787M
  • BCM5906
  • BCM5906M
Supported Vendor ID and Device ID
  • 14e4,165a
  • 14e4,167a
  • 14e4,1672
  • 14e4,167b
  • 14e4,1673
  • 14e4,169b
  • 14e4,1693
  • 14e4,1712
  • 14e4,1713
  • 14e4,1691
  • 14e4,1698
  • 14e4,16b5
  • 14e4,1692
  • 14e4,1600
  • 14e4,1681
  • 14e4,1680
STEP 1: Adding Required Kext
1. Download BCM5722D.kext from the downloads section of this forum.
For Clover:
If you're using Clover, copy the kext to EFI/Clover/Kext/Others
For OpenCore:
If you're using OpenCore, copy the kext to EFI/OC/Kexts. You'll also need to add the kext entry in the Kernel section of your config.plist.
STEP 2: Restart your System
nnaa
