Dell Optiplex 7460 AIO
After you get these, let me know, so I can remove them, not sure how to get what you're wanting, hope this helps
Dell OptiPlex 7460 AIO
Why using a MBP SMBIOS when you don't have a Mobile CPU? Your system has 8500 for which iMac19,2 should be used.
Moreover, the EFI you have, is really a mess and definitely not as per the guide.
Was going to send you a pm with the link and the link to my .spx but I don't have 50 post yet so not able.
Have sent you a PM.
I used the mackbook one by mistake, and it was the first time I had any luck with enabling acceleration, so I left it alone. :/
can you please share the EFI
can you please share your EFI im stuck for whole week now
I'm pretty sure this is it. It's not polished, the screen
died so I just moved on
thank you so much it helped alot i have an optiplex 7470 i fixed ethernet and wifi on Mac sonoma
the only problem i get is that internal display shows pink color
that's an easy fix HIDPI Fix
Can you please share your EFI / config?
scoobypetey
