Dell Latitude 7480
ViDaVario
Dell Latitude 7480
Inel(R) Core(TM) i7-6600U CPU @ 2.60GHz
Intel HD Graphics 520
Hello, I have a question
I try build macOS installation with OpenCore, but boot screen stuck on 30% loading bar at apple logo and then laptop was restarting.
Clearing, Reset NVRAM do nothing
Disable SIP - same effect
Laptop specs:
Intel i7-6600U (Skylake)
24 GB RAM
254 SSD M2 disk ?Patriot?
Touchscreent
Intel WiFi and ethernet
what could I be doing wrong that I can't install macOS ... I tried every edition starting with Big Sur
Boot using Verbose mode. Attach photo/video.
Attach your EFI to check.
Hello. One thing. Make sure what Intel have you got and use your right EFI. Remember: don't conect to Internet (if you update from BigSur or Monterey). I have a perfect Mac book Sonoma on Dell 7490.
Here is my EFI in attached file.
I will install possible to newest macOS (Ventura or Sonoma).
And in future I will add to this laptop WiFi + Bluetooth card, WWAN 4G card, smart card reader and fingerprint reader.
Actual Specs (decoding Dell Service Tag):
Intel Wireless-AC 8265 Wi-Fi dual-band wireless card without Bluetooth module
4-cell 60Wh battery with ExpressCharge support
M.2 256GB SATA Class 20 Solid State Drive
14" FHD (1920 x 1080) Touch
Intel Core i7-6600U
24GB RAM DDR4 (upgraded from 8GB)
Internal US/International Qwerty Backlit Dual Pointing Keyboard
No mobile broadband card
Intel Core i7-6600U
Have you installed or what?
natsukiro
