Can’t get HDR to show up in settings
Also, from what I understand, WiFi is going to be an issue if I update to Sonoma as it dropped support for most Broadcom cards (including the one I have)
Disabling SiP to get WiFi working isn’t ideal
Exactly.
Well I always had the dev menu enabled because as a web developer myself, I do use it.
So yea, still no YT HDR
You most likely have some custom user agent active in that menu which is what fixes the HDR issue for you
Not at all.
I was able to get HDR to work on YT by using Chrome.
But it was rendering it on my CPU instead of the GPU.
And I kinda only want to use Safari so it’s not very useful to me either way lol.
Not sure what's the difference as it works at our end on the Safari. We have the latest Ventura and Sonoma.
Yea, it’s a weird issue.
Also, it’s worth noting that I have a second monitor connected as well (it’s a 1080p 144Hz one without HDR)
Umm, maybe that's making the difference? Try with the HDR monitor only.
xmax114
