Dell Optiplex 7460 AIO
Done just as I figured I would, It's in the back room in time out LOL On an Otiplex 7400 AIO
Intel i5-12500 Alder Lake 12th Gen Right now. Isnt the newer Airport cards (BCM943602CS) supported in sonoma?
Nice. No Broadcom cards are supported on Sonoma. Just which are soldered by Apple in newer generation. xD
  • Sad
Reactions: 03hdfatboy
Some reason i cant get bootloader to work now. using the same one on the same USB drive I used to install it the first time. I had that once before but dont remember how I got around it.
Got bootloader up using a basic Coffee lake EFI, formatted drive, now at installer in Korean, I'll have to fix it after reboot. Oh, and get this, the touch screen is working, so gonna have to check that out too if it still does after it reboots.
I have it back up, running great. Everything works, had touch screen where mouse moves by touch as it should, but couldn't tap to select anything, so I just removed it for the time being. My Biggest issue now is if I place the boot and OC folder in EFI pc will not boot says no boot device. If I leave them in the EFI folder and paste in EFI partition it will, but boot screen shows 3 choices EFI macOS and Reset Rvram. Si I have to select macOS or efi will be chosen automatically, screen goes black and it just sits there. I assume, in boot picker settings, I'm missing something?
Attach your EFI to check.
Also, can't adjust backlight. I found a post on how to fix for laptop but with the All In One it disables acceleration after vram reset and reboot. I hope this isn't like tonymac where I post EFI and get banned for violating copyright fourm rules Dell OptiPlex 7460 AIO EFI
One more question, do I even need to spoof my device id with coffee lake? When I first got acceleration working the screen had pink/purple tint. I fixed it with hidpi
  • Haha
You would need to attach the complete PR Files. IOReg, Hackintool PCIe Info, System Report.
Such practice is not followed here. xD
Sorry for all the questions, but I'm soo close to having it perfect. If this was windows (pre Win 8) and 20+ years ago when my brain worked quicker, I'd be on the other end of this conversation. But birthdays eventually get us all. :(
I noticed something new this last go-round. I can receive text msg from non "iMessage" devices now. Don't know how the h#ll I did that, :)
After you get these, let me know, so I can remove them, not sure how to get what you're wanting, hope this helps
Was going to send you a pm with the link and the link to my .spx but I don't have 50 post yet so not able.
As long as it works, it's all nice :)
mng062
