How to Disable SIP (System Integrity Protection) [Clover/OpenCore]
UUIDKeyValueTypeNotes
7C436110-AB2A-4BBB-A880-FE41995C9F82csr-active-config
  • 00000000
  • 03000000
  • FF030000
  • FF070000
  • FF0F0000
  • 67000000
  • 030A0000
DATA
  • Defines SIP type.
00000000
  • Enables SIP completely. (0x0)
03000000
  • Disable kext signing (0x1) and filesystem protections (0x2)
FF030000
  • Disable all flags in macOS High Sierra (0x3ff).
FF070000
  • Disable all flags in macOS Mojave and in macOS Catalina (0x7ff) as Apple introduced a value for executable policy.
FF0F0000
  • Disable all flags in macOS Big Sur (0xfff) which has another new flag for authenticated root.
67000000
hi im using OCLP and i get this message when im trying to disable completeley the SIP
System Integrity Protection status: unknown (Custom Configuration).
Configuration:
Apple Internal: disabled
Kext Signing: disabled
Filesystem Protections: disabled
Debugging Restrictions: enabled
DTrace Restrictions: enabled
NVRAM Protections: enabled
BaseSystem Verification: enabled
This is an unsupported configuration, likely to break in the future and leave your machine in an unknown state.
What should i do?
The real Problem is when i try to set custom resolution with switchres x the status bar mentions 'not installed' so im thinging the problem is SIP
Any Suggestions Please?
Configuration:
What should i do?
Seems like you're checking it in Terminal. Provide a screenshot of the issue.
Screenshot of what? Terminal? I need to disable SIP completely
Check OCLP How? and where to check?
Seems like you're confused. If you need to run OCLP, SIP must be disabled for root patching. Is that what you're trying to do?
NO i need to disable SIP for Swtchresx. It says resulution status 'not installed'
SwitchResX does not require SIP to be disabled. Use 67000000 and then check. Try installing the software correctly. BTW, why do you even need SwitchResX?
i need SwitchResX for setitng res for my monitor 2560x1080. I have mac mini 2012 and having hardtime for setting res 21:9 Ultrawide. I tried with a miniDisplay to HDMI but nothing works,the screen is still stretched.Any Suggestion what should i do?
xxxxxxxxxx
