Need help getting Sleep to work Sonoma 14th gen
cafe2022
Premium Member
Asus Prime Z790 Plus D4
i9
AMD rx 5500
Z790 Asus ROG Maximus Hero
I put the PC to sleep:
screen turns off,
CPU fan still spinning,
tries to Hibernate (.5 sec) then immediately spins CPU fan and video card fans back up.
This continues to repeat.
Things I have done:
Mapped USB Ports : USBPorts.kext
Set HibernateMode to "None"
Set bios setting under AMP Configuration
Thank you!!
screen turns off,
Things I have done:
Thank you!!
Attach your PR Files to check!
config.plist attached
Thanks
Thanks
Incomplete PR files attached.
ilikeeatingpeeandpoo
