SOLVED RX580 Hardware Acceleration Mac Pro 5,1 Sonoma
Neve
GIGABYTE Z690 UD & Mac Pro 5,1 dual CPU
i9 12900K & Dual XEON X5690
AMD RADEON RX 6600 XT & RX580
  2. OpenCore (Legacy)
  2. Mac Pro
Hi all,
This is my first post here, so I'm not sure this is the right forum. Let me know if it's not.
I have a Mac Pro 5,1 mid-2010 which runs Sonoma 14.1.1 very well. However, I have an issue with my XFX-RX580.
I'm running OCLP 1.2.1 but, according to VideoProc, I don't have H264 acceleration. I do, however, have HEVC acceleration. I'm by no means an expert, but I do find this rather odd. Can someone explain, and tell me a way to fix this??
Thank you.
Hi all,
Thank you.
Are you using OCLP to boot? If so, attach the EFI.
Also, are you having Graphics acceleration? XFX cards have issues on Mac side.
Yes, I'm using OCLP 1.2.1, I think I mentioned it.
What do you mean by "attach the EFI"? You want the entire EFI folder in a .zip file??
You can see the acceleration I have. I attached the screenshot.
Thanks
Yes, please. Also, include a System Report.
Thanks
Ok. I'm sending you the files privately.
...Apparently I can't, or I don't know how to send them privately...
Thanks
Thanks
You can send it in this thread. It won't be an issue.
Reactions: Neve
Problem solved. The issue was that my SMBIOS Spoof Level was set to "None".
Glad to hear that. Marking the thread SOLVED and closing it.
xmax114
