Hardware acceleration not full intel HD 620
Lucpop2007!
HP laptop 17-by0006nf
i3 7020u 2.3 GHz
Intel HD 620 (1600x900)
12.0.x
  1. OpenCore
Hi everyone !
I am facing with a problem with Monterey 12.1 with OpenCore 0.7.5.
I have successfully install it but I have glitches on the internal screen, the dock isn't translucent like QE/CI is not fully activated.
I have no HDMI Audio too...
I have tried many patches, tests but nothing worked, can you help me ?
I attached my config.plist and a screenshot, I think I have trouble with device-properties.
  • Files.zip
11.0.x
  1. OpenCore
Hi everyone !
Incomplete PR files attached.
IOReg, Kextcache Output and EFI folder is missing. Also, are you sure that your screen resolution is 1600x900? It should be probably between 1366x768 or 1920x1080, unless its 4K/UHD/QHD.
Lucpop2007!
i3 7020u 2.3 GHz
12.0.x
  1. OpenCore
Oh yes I forgot these. I attached them.
Yes I am sure that it is the max resolution for this laptop, you can check on the screenshot.
  • Additionnal files.zip
11.0.x
  1. OpenCore
As per the files, the VRAM is working. Although, the platform ID you injected is for Desktops. For Laptops, the ideal Platform ID would be 00001B59
Lucpop2007!
i3 7020u 2.3 GHz
12.0.x
  1. OpenCore
I tried 2 patches :
- replaced 00001619 with 00001B59 -> No HDMI, no internal screen and brightness doesn't work
- try another device-properties with 00001B59 -> graphics works perfectly, HDMI Audio works, brightness works but internal screen still black.
I attached IOReg and a screenshot of the new device-properties.
  • new patch 00001B59.zip
11.0.x
  1. OpenCore
I tried 2 patches :
You shouldn't need Device ID.
Lucpop2007!
i3 7020u 2.3 GHz
12.0.x
  1. OpenCore
Okay, i have followed the guide and replaced the device-properties from the guide.
First attempt -> internal screen black but brightness works. No HDMI...
Second attempt -> modified some properties and everything work, except internal screen which is still black...
Attached IOReg...
  • files.zip
11.0.x
  1. OpenCore
Attached IOReg...
Add igfxonln=1 to your boot args and then check.
Lucpop2007!
i3 7020u 2.3 GHz
12.0.x
  1. OpenCore
It didn’t changed anything.
11.0.x
  1. OpenCore
Similar threads
twj168
