SOLVED Does a ASUS ROG G14 (2020) actually support a hackintosh ?
I need a new kext or driver, or maybe the config file is not good ?
How can i get these files ? And it's a screen of disk util when i erase the disk (i think it's probably the serial number).
Seems like Intel 660p which is a supported SSD on macOS.
Try to remove AMDRyzenCPUPowerManagement.kext and SMCAMDProcessor.kext and then try. Make sure to reset NVRAM and again erase the whole drive completely.
Ok i try this, also when i shut down in recovery os it reboot so maybe another problem ?
That's a separate issue and can be fixed during post install.
Yes ! It not works, the macOS installation crash at 12 minutes remaining. It's sad, i think it's not possible to install it on this laptop...
I do all you said. Ideas again ?
Try to install on a different SSD. Use an offline installer.
Another SSD change nothing, i see for offline installer, maybe a problem on the usb key ?
Finally working with the github !! Thanks for all the helps !! For now I don't what was the problem but there it is, I have macOS on my laptop !!!
Can you share with me the EFI file? I'm also having the same problem with my laptop configuration (4800hs 1650)
natsukiro
