Cant login apple id it says cant communicate to apple server
can i know is this model works well on this system as i am thinking to buy an wifi and bt adapter 1696498777214.png
still Apple ID cannot communicate to server even en0 is there
It might be possible that you have not removed the network preferences yet.
Go to /Library/Preferences/SystemConfiguration/ and delete the following:
  • CaptiveNetworkSupport
  • Com.apple.airport.preferences.plist
  • Com.apple.eapolclient.configuration.plist
  • NetworkInterfaces.plist
Go to System Preferences > Network, select all available connections and hit the Minus button to delete them, then hit Apply. Reboot
Go to System Preferences > Network, hit the Plus button to add the devices back, but be sure to add Ethernet first
while installing mac os Sonoma its shows while i boot from usb and it stuck on this area any idea sir to pass it
That's a separate issue. Please create another thread to track the issue.
Legacy AMD Guy
