HELP:)
alprox
asus zephyrus g14 (GA401QH)
AMD Ryzen™ 7 5800HS
NVIDIA® GeForce GTX™ 1650 , With ROG Boost up to 1515MHz at 50W (65W with Dynamic Boost), 4GB GDDR6
  2. OpenCore (UEFI)
Hello, I have successfully installed macOS Ventura on my laptop, but I am facing some issues. The problem is related to CPU idle usage. When I open the system monitoring in macOS, the CPU idle percentage averages around 95%. This causes my laptop to heat up. In the macOS system, my CPU is detected as Intel Xeon W, and the iGPU is recognized as 512 MB. The second issue is with the trackpad. Sometimes the screen and mouse freeze.
Provide the EFI you're using to boot.
Reactions: alprox
This is my previous OC file, as well as the screenshot of my Mac OS system monitor. I'm not sure if the issue lies with the fan or something else, but the temperature of my laptop feels like rendering 4k in Media Encoder on a Windows operating system, it gets hot. I'm also experiencing audio issues and internet tethering through Android
There is nothing wrong. The CPU usage is near about 1-1.5% which is really fine. If the usage would have been 98%, there could have been issue, but its idle which does not indicate any underlying issue.
Reactions: alprox
Write your reply...
ambruhidot
