Hello i have successfully installed mac os mont. in a laptop i made my custom efi for my laptop but the thing is i know that i have rtx 3060 which is unsupported and i have a amd cpu named r7 6800h with its integrated graphics but when i perform this method but this aint working here is the my gpu name is it still unsupported (rembrant amd graphics 680 something like this) so is there any way to install haackintosh on my laptop? i also have a mux switch just in case i have to use it can you please reply this thread Thank you
EFI : https://drive.google.com/file/d/13VQSbOWeVdk0xc8OGU3NGmpLHBW5Kd_L/view?usp=sharing
Try to add: -wegnoegpu in bootargs and then check.
I tried this but not it gets blacked screen after some lines and gets restarts can you please check my efi folder just the changes are i enabled whatever kext and added that command is that anything that i have missed?
Provide the EFI to check.
No. Please read the guide.
means my igpu(apu) supports it right? and i followed your guide there was no whatevergreen kext and i updated to latest lilu kext and rearranged
GabyXB
