Thank you for the response. Please keep my EFI folder.
An interesting fact, I had no issues with Big Sur booting up, when I just tried to install Ventura, instalation stuck at EB|LOG:EXITBS:START.
Why using Laptop SMBIOS?
Patches must be updated for the newer version of macOS
Your advice was spot on. I updated everything that could be updated and also changed the SMBIOS, successfully installing Ventura. Thank you for the guidance. I've read that Android Studio isn't supported at all; I assume there are also issues with the iOS emulator in Xcode? I've tried running it, but it's very laggy.
Anytime :cool:
Well, no idea. Haven't tested that.
hello, I tried to install nootedred along with all accurate kexts and after verbose mode it gives a black screen, I see the problem is solved in the comments, but nothing above helped, like disabling SIP, seeing bios settings, checking kexts and etc. need help.
my specs are on my account, heres my efi.
try put (unfairgva=1) in bootargs. works for my 5600g
try put (unfairvga=1) in bootargs. works for my 5600g
u
I RAN INTO PROBLEM IM HAVING ERROR APPLENVME ASSERT FAILED LINE 5669
MY LAPTOP IS LENOVO 15ADA7 (RYZEN 5 VARIANT)
HERE IS MY EFI
AND IM TRYING TO INSTALL VENTURA WITH ONLINE INSTALLER (OPENCORE 0.9.3)
Have you manged to fix this issue, since i have the same specs as you
How do I attach it
Tryed is same OpenCL is crashing Metal is very slow, in big sur is not been much used in Ui is not big deal for normal use.It seems is something with my laptop.I will test on another laptop 4700U and 5800u when i have some free time with same method i used for this one to see is it somthing specific to my laptop or not.
It seems problem is connected with SMbios generation i changed to iMac-pro1,1 regenarated serials rebooted into Monterey and pass geekbench OpenCL and Metal , then i returned to bigsur again test fail again , so i decided to clear NVram , then reboot again to monteray and now geekbench fail again to pass OpenCL and Metal , it seems this make some kind of problem , is good i keep copy of my EFI so will retest same think again tomorow.
P.S the same think happend with my Proxmox hackintosh with VA decoder if i use Imac-pro smbios is fine , if i not use this profile VA is not working so same is happening here with this kext some how metal and openCL need proper SM-bios to work , OpenGL is not affected from this !
alvarg82
