Issue with sleep mode and fans always on (no sensor found !!!)
carlitosh
Gigabyte Designare z390
i9-9900 K W/ 64Go of DDR4 3466 corsair
AMD Radeon RX 5700 XT 8 Go
  1. iMac Pro
  2. Mac Pro
  3. MacBook Pro
Hello,
I'm new on this forum and I am having issues w/ my config.
Here she is :
  • 1x Gigabyte Z390 DESIGNARE
  • 1x Intel Core i9-9900K (3.6 GHz / 5.0 GHz)
  • 1x Corsair Crystal 680X RGB - White
  • 1x Crucial BX500 2 To
  • 1x Seagate BarraCuda 4 To (ST4000DM004)
  • 1x Sapphire PULSE Radeon RX 5700 XT 8G
  • 1x Corsair Vengeance RGB PRO Series 64 Go (4x 16 Go) DDR4 3466 MHz CL16 Noir
  • 1x Corsair Hydro Series H100i PLATINUM SE
  • 1x Gigabyte GC-WB1733D-I
  • 1x SSD Crucial P3 2To M.2 PCIe Gen3 NVMe (Boot MAc OS)
Connection for graphic on GC via Displayport
As of 3 months, when my precious goes to sleep, she will not restart and get out of sleep but it worked before. -> Reboot
Sometimes, I get a green screen and bye bye -> Reboot
I went on different forums w/ the sleep mode trick tc, if anyone has a great idea, i'm going for it :)
OCAuxTools gives me this error also and I don't know how to fix it :
NOTE: This version of ocvalidate is only compatible with OpenCore version 0.9.4!
UIScale is set under both NVRAM and UEFI->Output!
CheckUefi returns 1 error!
Completed validating /Volumes/EFI/EFI/OC/config.plist in 1 ms. Found 1 issue requiring attention.
That's all folks :D
Cheers
I Solved the UISCALE like a big boy :p
But Still got the fans overdoing it ...
I was wondering if it could be a cabling issue. I'm gonna test my w11 boot if it still works 🤣
Maybe i missed something.. or a cable dropped while I was unplugging lights.
Provide your PR Files to check further.
OK, I found the FAQ about this, I'm doing it ASAP. Thx
I am on to it and found another issue as I updated to Sonoma... I messed up the ethernet as it seems to have issues with the z390 cards.
I have postponed dealing with the fan issue for the moment.
Thanks for your feedback
What do you mean by Z390 Cards? Z390 is a chipset from Intel and there are Z390 Motherboards.
Yes the motherboard. Sorry in French we talk first of cards and after the use.
I had the issue with Ethernet on the designare after update to Sonoma. I followed a thread you posted on this issue and only made things worse so I had to reinstall everything from scratch.
I will try again the maneuver but first I’ll clone my disk to be sure.
kocsik
