Works quite well at our end. No crashes in Geekbench or any other App as reported by the community members.
You have idea what can be the reason OpenGL to work good but to crash on geekbench and low metal score ? Anyone tested at Ryzen 5800h ? or maybe just bugy on my specific laptop or some mistake i did on ACPI generation maybe ?
Highly possible that something is within your EFI. Attach your PR Files to check further.
Hi, I have an HP Victus 15-fa0000. It has AMD Ryzen 5 5600H with 8gb ram and Nvidia 1650. I tried to follow youtube guide. My bios side of things is configured good. I try to boot my laptop with it but it keeps giving me these errors. Image and EFI is attached below. Please help
  • EFI.zip
    EFI.zip
Your configuration is not as per the guide. You're just blindly following the guide and configuring as shown. However, as you don't have the exact hardware, the parameters will change in your case. So, use the parameters as shown in the guide.
I'm just new to this scene that's all. I just want to know if my hardware is even supported or not. I'll try and redo the process again.
Of course, its all supported.
besides, in the guide(this one- https://elitemacx86.com/threads/getting-started.14/) there is no AMD Laptops section as well which make me in doubt if it is even possible on my laptop
alvarg82
